z1 battery
JamieWills23
z1 battery
Hi I was just wondering about the z1 battery? Ive had my z1 a week now and im always turning it off whilst im at work,  will this aaffect the z'1s battery?
3 REPLIES 3
profile.country.RO.title
_alexdon_
If you turn it off,there is no problem.But make sure the battery is not under 10% when you are doing this.
alexdon
JamieWills23
Thankyou, I was just wondering if frequently turning it off and on would affect the battery life at all, but thankyou for your help
_alexdon_
There should be no problem,but as I told you,do not turn the phone off when the battery is either <10%,because after that you will need to charge it some time before you can turn it back on.
alexdon
