z1 compact Google maps not working
jayy26
Hi I've not once been able to use Google maps..it loads up fine sometimes finds my location but when I try use the directions function it loads it up but then is always trying to find gps etc and does not work as a sat navigation...it works fine on messenger app etc..I've tried downloading another maps app but problem still persists 😕
2 REPLIES 2
Thommo
If this is an issue with GPS then try performing a diagnostics test on the GPS
Jake-SonyXperia
Champion
Hi jayy26,
This could also be related to the application directly. I suggest a removal of the apps data and then attempting the function.
Menu > settings > Apps > All > Google Maps > Clear Data.
If this does not work try an unstallation of the updates.
Menu > settings > Apps > All > Google Maps > Uninstall Updates.
Let us know how you get on.
