Just to be clear.
Noise canceling headphones do not work on your Z3 tablet.
Galaxy Note headphones are working fine on your Z3 tablet.
Is that your situation?
Could you try your NC headphones on other device? For example ask your nearest Sony Store or electronics market to let you try on Z2, Z2 Tablet, Z3, Z3 Compact, Z3 tablet to make sure if something is inside your device or with headphones connector.
Glad to hear that you got it working.
Not sure what could have caused this. It should work out of the box without downloading any apps and i haven't been able to replicate any issue here. Please let me know if you should encounter more issues when using the headset with your tablet.
Thanks for the feedback and sorry to hear that you encountered this again.
I'm still trying to find a way to replicate this. If i understand you correctly, it happend when you first started the music player (for example Walkman) and then connected the headset? Do you remember if music was playing while you connected the headset? Have you connected any activities to the headset in Smart Connect?
