Z3 Touchscreen Problems (After Being Dropped)
Will6
I went for a walk today and I dropped my phone. It landed on the back on a soft surface, and since then the touchscreen has been completely unusable. It has a slight crack going all the way across the screen towards the bottom. The touchscreen is uncontrollable because it randomly presses things without you ever touching the screen, and you cannot open apps that you want to. I can't see any way of fixing it apart from replacing the screen or the phone, but if anyone has a solution please tell me! I would really appreciate it!
Thanks.
Picture of the crack below:
1 REPLY 1
Uliwooly
@Will6
you have to replace the screen (LCD + digitizer come as a unit) either DIY or contact your Local support
You can also buy a OTG USB + Mouse so you can control the phone with the mouse instead of the touchscreen.
