Started appearing after the latest software update. Comes and goes, but only when turning on the screen after a few minutes with the screen off. Usually able to get it to go away by turning the screen off and on a few times, but sometimes that doesn't work and I have to wait for it to go away on it's own.
Anyone else having this issue? Is it software related or a hardware problem?
I found this thread via search. Wife has had her US version of this phone (white) for less than 2 weeks. Screen started having this identical problem with green areas, sometimes worse (screen gets image blurred or something). I tried a factory data reset to no avail in case something got messed up after the Marshmallow update. I'm guessing there isn't just much else I can do and just assume it is just faulty hardware, like for the OP?
I can say that, the green screen issues is LCD/Screen problem.
I have the exactcly same problem too. and have to send it back for warranty.
They said they had change the lcd. And the green screen issues gone too.
me,my phone is green everywhere and i cant see anything
