- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
1. Please remove the double click for enable Internet access. One click on the Internet icon should be enough (like wlan) and not second on the switch on/off.
2. Please remove the notification that Internet access is on/off. You could make it like " don't show this again "
3. For what is the headphones icon when I plug them in? I can't disable it in the system symbol settings like I can disable " % in battery or Bluetooth " for example.
Last and not least, thanks for remove Spotify as bloatware
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @fetch93,
Thank you very much for the feedback.
I can understand the comments regarding the data enabled and disabled, however, these do help the user understand what is currently running on their device, and as the internet is one of the most important parts of a smartphone, it is always good to know when the service is on or off.
Again thanks for the feedback.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @fetch93,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
