Android Oreo8
Sohaib88
Android Oreo8
Nice 😍😍😍
5 REPLIES 5
SamiSawani
It is nice but also disappointing. For once, there is no color gamut options in the display settings. This option is not hardware dependent yet sony hasn't included! It is useful to be able to switch between different color gamut options so that the screen can look as one desires.
Also, the camera app is not updated like xz1 and xz premium;ie. Still separate 4k mode and no burst mode.
On a positive note, the battery seems to be improved which is great. As for the performance, it is roughly the same.
Other than that all is good so far. I'll update if something changes
Sohaib88
My friend regarding the color gradient available ???
SamiSawani
Yes, in Xperia xz1 and xz1 compact there is a color gamut option in the display settings but it's not the case with the xz even though all the of them have oreo now.
SDR1970
Contributor
Do you guys mean the white balance?
DanneLeo
Basically its just a UI change. But kudos to Sony for the speedy Oreo update.
