Android Wifi issue
Nighty21
Android Wifi issue
Having two seperate router in house, both saved. But won't switch over to other network when it's low connectivity at current network and  nearby one having strong signal.
Could someone configure a way to make wifi connect another router when current one has one bar signal and other has more than two bars of wifi signal.
Cuz whenever phone has one bar signal strenght with wifi network, it simply won't work. Just stays connected with wifi network without internet.
This fix could fix so many issues android having with places which share same network with different routers/Access Points.
Tags (4)
2 REPLIES 2
geowills
I read the post and would like to discuss my problem also. My Linksys Router ea7500 is also dropping internet connection after visiting here still have issues if anyone will try to find out the solution from the link please share me or give me a genuine solution.
mahesh911
Contributor
@geowills wrote:
I read the post and would like to discuss my problem also. My Linksys Router ea7500 is also dropping internet connection https://www.routertechnicalsupportnumbers.com/blog/linksys-router-keeps-dropping-internet-connection...after visiting here still have issues if anyone will try to find out the solution from the link please share me or give me a genuine solution.
Do u have WiFi connection issue after u restart your phone?
To minimise problems one thing to do is set 802.11'n' only setting with 40mhz bandwidth.. along rest all at default setting.. Restart both router and phone after making changes in those settings.
In the modem configuration there is a DHCP server setting also where the DHCP IP expiry time shown probably 24hours which it automatically renews but sometimes after expiry loses the internet but WiFi connection stays. So set it to 1 week if the option allows.. and see if u r getting continuous net connectivity.
And if still have issues, XZ PREMIUM also has kind of WiFi connection issue which appears randomly and solution is to simply restart..
Hope u can atleast minimise the issue from reoccurring..
