Application lockscreen.otp is virus?
Martinblack
Buen día alguien sabe si la aplicación lockscreen.otp es virus, no le marca ningún error pero al revisar las aplicaciones de mi smartphone encontré es aplicación revisando en Internet encontré que se trata de virus tipo ransomware, espero que alguien me pueda ayudar
Saludos
Good day someone knows if the application lockscreen.otp is virus, it does not mark any error but when reviewing the applications of my smartphone I found this application reviewing on the Internet I found that it is a ransomware virus, I hope someone can help me
regards
-GT
3 REPLIES 3
FunkSony
Pay ransom or battery dies
profile.country.AT.title
skycamefalling
Contributor
I'm pretty sure that there are several apps with this name. Some might be legit, some might be a virus.
Why don't you just deinstall the program if you are unsure?
I can tell you that it's not a system app, because there's no process or app named "lockscreen" on my Xperia.
profile.country.NL.title
Strampke
And when you're afraid that you installed ransomware or even a virus I would completely reset my phone.
Who knows what remains after uninstalling!
My suggestion: Do a software repair using Xperia Companion.
Watch the video here.
