Audio issues
Mnoor
Audio issues
After the last update, the sound became very weak in the stereo and communication programs I need to put the earphone to hear without hearing the sound very weak and very frank disturbing the status of the ear in everything I want to look at it I locked the mobile so once and open it and went to the settings everything is very sound but very very weak I hope solution The problem of sound is haraam and this is expensive and its voice is bad even when someone hears a sound clip of the waltz and says, "Why is this sound so weak?"
بعد التحديث الأخير أصبح الصوت جدا ضعيف في الاستديوا وبرامج التواصل لازم أضع السماعه لكي اسمع بدون سماعه الصوت ضعيف جدا وصراحه جدا يضايق وضع السماعه في كل شيء اريد ان اتفرج عليه قفلت الجوال كذا مره وافتحه وذهبت للاعدادات كل شيء تمام لكن الصوت ضعيف جدا جدا اتمنى حل مشكلة الصوت حرام جهاز زي هذا وغالي وصوته سيئ حتى عندما يسمع احد عندي مقطع صوت بالواتس يتضايق ويقولوا ليش كذا السوني الصوت ضعيف لايسمع المقطع اتمنى حل مشكله الصوت
1 REPLY 1
Uliwooly
@Mnoor
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Are you experiencing the audio issues with the preloaded music app or which apps?
