Back and home buttons not responding
Cfm
After unlocking my phone, the back and home buttons do not work at all but the rest of the screen is responsive. What can i do to fix it. I have tried restarting multiple times and this did not solve it.
Before unlocking my phone that section of the screen is responsive but afyerwards not, so i think it is not a touch screen issue.
6 REPLIES 6
Damir2
У меня тоже самое . Вам удалось исправить?
I have the same . Did you manage to fix it?
gt
Asche
Are you using a theme? Try to use the default Sony theme and see if that affects the navigation or not.
Jonas
Master
Hello everyone, sorry to hear about this. Slightly_frowning_Face
@Cfm, could you try and do the touch screen test that is available in the service menu of the device and see if it works at these specific places on the display? You can find the test if you open up the Phone application and type in *#*#7378423#*#* > Service tests > Touch > Free drawing test.
@Damir2, Your question has been translated to English as this is an Internal forum.
Do the same test as I recommended @Damir2 to do and report back how it works in this test.
Let me know how it goes!
Cfm
Thanks for your reply.
The free drawing test works for all parts of the screen except the home/back button bar.
I also tried the blue button test and even the numbers on the bottom work but the home/back buttons do not.
I also tried changing themes but this solves nothing either.
Cfm
Jonas
Master
Hi @Cfm, thanks for the update!
In this case, I would recommend that you perform a software repair using Xperia Companion. This will reinstall the latest available software version in your device and will tell us if this is caused by the software in the device, or if this is a hardware defect.
As always when resetting the device, it's important that you create a backup and you do that with the same program.
If there is no change and the back and home buttons are still not working after the software repair has been completed, get in touch with your Local support team and they will arrange a repair for you.
Feel free to keep me posted!
