Battery Drain
doministry
Battery Drain
I have an unexpected battery drain.
It never happened before on any Xperia I've had.
Now even on idle it eats like 6, 7% overnight.
Crazy since it was always like 0%.
What is the process which can cause that?
Sunking1011
Contributor
Look at running processes in developer options and see which apps (not system processes) are constantly running. Facebook and FB Messenger will be two if you have them installed and from this list you might decide to ditch some apps.
16 REPLIES 16
Lord_viridis
In the morning, check in battery settings which app is consuming power.
doministry
Thanks mate.
I do check it always since I'm quite a conscious user of my phones.
But nothing unusual there actually.
Sunking1011
Contributor
doministry
This I know as well. I always monitor that.
The problem is I never had to close any processes exept Snapchat and Instagram to keep by batt life just perfect.
Now nothing new there yet the phone eats battery even on airplane mode even if it was like 0% through the night. And that's why I try to track the problem.
Salsoul72
It seems I have a similar problem with my Sony Xperia Z1 Compact. The battery is gettiung super warm and draining very fast. First when selecting flight mode it would help, but now out of a sudden not any more. The problem is getting worse because now also the touch screen and apps are getting blocked. Anybody any soltion or tip?
Thanks.
Mamayo
I've checked and the result is Android Or, it is frustrating when android OS consume more battery than screen on daily use.. Xperia Z3 Compact marshmallow
Yuaru
My Xperia XZ battery drqin. Android OS keep device awake
Paintingjo
You shouldn't have to ditch apps that's the whole point of the phone! Get a Huawei they last forever
Hprl
Hi, I am afraid I can't offer any solutions, only confirming that this is an issue. Over the last 5 to ten weeks the Android OS has taken the major part of my battery capasity, usually between 25 and 35 per cent. I event suspect it is more, as I have to charge the battery at least twice per 24 hour with moderate use and no kind of social media apps.
I'd be very happy to know if anyone knows of a fix to this.
PS: The OS 7.1.1 (with security update 1. September) and all apps have latest updates.
