Battery drain fast, and i think screen on time is not that good
My mobile standby is also very power hungry.…
Even if Using Xperia companion to fix it …
It seems that power consumption is more serious on 10.80 version.
APP will not show up in battery usage
Mobile network standby is second only to bright screen
There is also an album to delete photos SD card problem. . .
I have not reported much hope.
Mobile data on stand by?? Then it's all bcos of play services as always.. I always turn on data saver atleast to limit it. But play services are play services...
With latest Google policy there is limitation to access other app data usage and that might be the reason the support app can't show all battery consuming apps. But still it wil show cpu engaged background running apps. Google did made some changes recently.
yes i also did turn on data saver atleast to limit it and turn on background data limit , i found this was on Wifi instead of mobile data...
Is it convenient for you to share the power usage of your mobile phone?
Does google have a source of evidence? Other phones equipped with 9.0 are quite normal.
@Avril wrote:yes i also did turn on data saver atleast to limit it and turn on background data limit , i found this was on Wifi instead of mobile data...
Recent Lifelog update did removed all app usage statistics bcos of Google.. after that support app also starts not showing app usage and details.. thought Sony cud fix that..in later support app update but still battery usage not shown.. only just we can the drop of battery graph to think it's normal or not..
I was watching a 4K uhd movie right now battery is now at 55% from 90. Iam attaching the battery graph , u can see the fall. And I wil later attach normal usage battery graph so u can compare.. 3 hour 4k movie watched.
That dip in graph was continuous chrome browsing, YouTube , Spotify.
And that's how quick charging works!
Guess screenshot pictures load up in the next decade.
