Bluetooth issues
Elsanto755
Bluetooth issues
Bluetooth is failing
Since the last update the bluetooth is being cut every so often listening to music with headphones of sony sbh 80 something that did not happen before this cut.
Bluetooth esta fallando
Desde la última actualización el bluetooth se está cortando cada cierto rato escuchando música con unos cascos de sony sbh 80 cosa que antes no pasaba este corte .
Uliwooly
@Elsanto755
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Just to be clear, you are losing bluetooth connection with your headphones?
6 REPLIES 6
Uliwooly
@Elsanto755
Diegoestrada84
Tengo tambien el mismo problema, mis audifonos Skullcandy y el parlante JBL de mi madre suenan distorsionado o se corta la conexión cuando escucho música o recibo llamadas.
I have the same problem, when i listen to music or recieve phone calls she sound gets interrupted or gets cut off in my skullcandy earplugs or my mother´s JBL amplifier.
The model is Sony XA1 Ultra.
El Modelo es Sony XA1 Ultra
Face_with_rolling_Eyes
Elsanto755
I have a jbl flip 4 and it is difficult to connect with my xz2 compact, and with other phones it connects to the first one. You will have to fix the bluetooth of Sony, it does not seem right.
profile.country.PL.title
najodleglejszy
try going to Settings > System > About phone and tap Build number 7 times. then go to Settings > System > Developer options and find option called Bluetooth AVRCP Version, and see if changing the version to one of other options and rebooting the phone afterwards improves the connection.
Elsanto755
It is true that I was in 1.6 and I changed it to the default and it seems that it is better, thanks
OtiliaZ
Thanks for the tip! Solved my Bluetooth issue too! Cheers!
