charging problem
idontreallyknow
charging problem
hey im having some issues charging my xz premium, well when i bought it 6 months ago i didnt have any problem, but now when i connect my phone to the uch20 it sometimes gets it charged, and sometimes it is impossible to make it work, I'm not sure but i think the problem is the uch charger, because when i connect my phone to the ps4 or my pc it charges like it would normally do, just a bit slower, but i find it a little wierd that the charger sometimes works and sometimes it doesn't, right now the charger is not working and i had to connect my phone to the ps4, but i bet tomorrow i will be able to charge my phone using it just as i could in the morning. Do you think it is a problem with the charger? Or the cellphone?. Im not an expert but i think the problem might be that the charger heats and it has to cool down to work properly.
1 REPLY 1
profile.country.PL.title
najodleglejszy
@idontreallyknow the easiest way to find out is to try using another charger with your phone.
