Charging stuck at 0%
Nekrom1
Last night my XZ1 suddenly stopped charging at while it was plugged into its original charger. The battery is now drained and I cannot get it to charge. The indicator (red charging light) would light up and it shows the charging animation, but it stucks at 0%. When I try to turn the phone on by force restart, the screen lights up with the "SONY" logo, vibrate once, then goes back to the 0% charging screen.
I have tried multiple USB ports and charging cables and have waited for hours for it to charge, but nothing happens. I cannot do software repair because the battery is already drained and my computer doesn't recognize the device. Has anyone encountered this?
2 REPLIES 2
CameronT
Champion
Hi @Nekrom, welcome to the community. I am sorry to hear about this.
Charge the device for at least 30 minutes. If the battery is drained, it may take up to 30 minutes for your device to respond to the charging. During this time, the screen may remain completely dark, not showing the charging icon. Also note that it can take up to 4 hours for a completely drained battery to charge fully.
You may also wish to try the 2 minute restart process.
To force a 2-minute restart
  1. Press and hold down both the volume up key and the power key Icn sony key and power k90 for 120 seconds, ignoring any vibrations.
  2. Release the keys. The device turns off automatically.
  3. Charge the device until a charging icon appears on the screen.
  4. Turn on your Xperia™ device.
Jacob1223
also the same case as mine, it just started not to charge for i dont know reason.
i bought another set of cable thinking it was just the cable but still the same.
i tried every 2 minute force restart but still stuck at 0% charging and cannot open the phone.
i didn't remember what i did but while just pressing random buttons it opened and restarts my phone and got 10% on the battery. but then every cable i have and original plug still dont charge it and im back with the same problem again.
i want to know if it is hardware problem so i will know if i need to buy replacement parts and what are the parts, is it the port or the battery or both? Sony please answer, the phone has been with me for almost 2 years only.
Additional: the OS is now on Android 9 pie so I dont think this method of 2 minute force restart is still working. please reply asap so i will know if i need parts replacement
