Hey,
My Phone vibrates when i get a message and calls. I would like to be able (as in previous Android-Versions) to turn off vibration or change the vibration-pattern. For example instead of *brrt* *brrt*just a short *brt*.
I found nothing in settings - notification, only under app - app info... but Thats not the way it should be...
Kind regards
Sebastian
It seems this can only be accomplished by putting the phone on do not disturb, resulting in a persistent notification in the panel.
Or are there other ways to globally disable vibration, anyone?
@Compactguy Settings > Sound > toggle "Also vibrate for calls" off. for other notifications, you'll have to check settings of specific apps.
Open Messages app, go to Settings -> Notifications -> Always vibrate
