Since I got the update to oreo, I have problem when display auto brightness is turned on. The display will instantly switch between light and dark backlight depending on if there is a light source or not in front of the phone. As an example: When I was riding in a bus when it was dark outside, the display turned up the display light for each street light we were passing, and turned down the light in between each. The display was flashing back and forth like crazy!
Any one else has got this problem since the oreo update?
Hi, the same experience unfortunately. Very annoying. Any idea or solution for this?
