Hello everyone,
since the Android 9 update my phone stopped to work in WIFI EAP-PWD networks. EAP-PWD is an enterprise authentication protocol for securing wifi in university / company campuses.
My phone succesfully connects to the network, but subsequently, after some number of reconnects due to walking in other rooms, fails to reconnect.
The WiFi component is then completely frozen. Therefore the Wifi settings app cannot be opened anymore. Please note that the error is Sony global, other phones of colleagues have the same issues.
I uploaded a log of such an unsucessful connection attempt: https://pastebin.com/vWJU8FWa
Best regards
Laurenz
It is sad to say but sometimes Full Software Repair (using Xperia Companion) is the best way to get phone to work correctly (after major software update). My personal opinion is that as some WiFi settings are left out from Android Pie then existing configuration files from Android Oreo cause problems. And this is something Google could have done better.
However, please do note:
you should back up all your personal information before that.
you should NOT restore system settings after software repair.
Before posting on this forum, I tried to get in touch with Sony customer relations. The sent me the same recommendation, so I tried that. I set up the whole phone by myself again.
The error is not related to Google AOSP sources, since other manufacturers phones are unaffected. All university members with Sony phones are affected, the others are not.
The new update is therefore non-complaint to the IEEE 802.11X standard.
Best regards
Laurenz
Dear Sony Staff,
will anybody of your reply to my post? My device is still under warranty and non-compliant to WiFi standards.
Best regards
