I noticed that when I use the phone after it's on idle for more than 5 mins, it drops frames of animations(like fingerprint unlock screen, app opening, notification pull down, etc). Did any of you notice this problem?
Yup always randomly encounter this. Just restart the phone since it restarts very fast.
I did not, but it sounds like it throttles down the CPU to converse power- check if there are any energysaving-relevant options enabled, then disable those.
