Headphone issues (again)
ErikJ123
When updating to the lastest Android version Soundabout stopped working and and at the same time my headphones stopped working properly. Now I only get sound from the right ear.
Is there another fix ?
I use Beats by Dre and have had no problems while using Soundabout.
If i deciede to waste more money on new headphones from Sony , how do I know these will work?
This is obviosly a software issue.
Im so sick of these expensive Sonyphones and their major flaws.
4 REPLIES 4
Lord_viridis
I would contact your Local support to get the phone checked, I assume you used soundabout after the headphones stopped working,
ErikJ123
I don't understand how that will help, it's a known software problem.
Is their another fix or do you know if I will get rid of this problem if I buy Sony headphones? Obviously Sony has made it troublesome to use other brands.
RuneJ
Contributor
What known software problem are you referring to?
If your headset is wireless/bluetooth, you could try to select an older version of the protocol (Bluetooth AVRCP Version) under Developer-section. -Perhaps 1.5 or 1.4 will restore connection to your headset.
If not, your headset is probably defective.
Danny8383
Very had nothing but issues with the low volume on this phone since the update, you can't hear a thing, they need to fix it with another update but seem to be ignoring it all together, for a £500 phone it's a disgrace
