I just received my xperia xz2 and is pretty excited about it.
For the headphones issue: make sure that the USB-C converter is firmly attached to the port. Then try clearing the cache of Smart Connect app by going to Settings -> Apps & notifications -> App info -> Smart Connect -> Storage -> Clear data. Restart your phone and see if the problem persists.
For the keyboard: Install Gboard from Google Play store and set it as the default input method, then disable Swiftkey from Settings -> Apps & notifications -> App info -> Swiftkey
Thank you! Restarting does solve the playback problem. And I am able to disable switf key right now!
