HotSpot, Gyroscope and fingerprint problem with Nougat and oreo
DanyMally
Hello to everybody,
I'm an XZP owner, and i noticed these 3 big bugs.
The hotspot is not working good, everytime I activate it, the SSID broadcasted doesn't allow me to reach internet, with windows pc, android phones and iPads.
To solve, i have to reboot the phone and activate it, then everything works.
If i deactivate it for a while, i have to reactivate it and is a bit annoying.
After a phone call, the Gyro is not working.
it means that the screen get stucked in landscape mode, and will not turn anywhere, until I lock and unlock the screen.
The fingerprint sometimes doesn't recognise the finger, I scanned 4 times all the fingers that I use the most, in most various way possible.
Sometime, if i lock and unlock the screen again will work immediately, but sometimes, i have to write the code, and after few second, if i try again work as a charm.
Tested in Oreo and Nougat (all of them)
Solution? Somebody have this issues?
Thanks
1 REPLY 1
pribambas
Contributor
The fingerprint reader stops working due to least moisture. Next time when it stops recognizing just dry your finger and try again. Yes, this is very inconvenient but "it's a sony". Most other vendors' devices don't suffer this problem. I created a topic for this problem some time ago, but there was no response.
