I own a Sony XZ1 with paired Sony WH-H900N headphones. I have a problem when I listen to music, and therefore I have an active Bluetooth connection between headphones and phone, the Hotspot does not work. The PC is unable to connect to the phone and navigate. DoesAnother case, when the PC is connected in hotspot with the phone the Bluetooth connection with the headset does not work. Does it happen to you too? Anyone have any way to try? I update the phone with the last firmware.
