How can I create message template on XZ2 compact, Oreo
PTrung
This feature is very important to me, but it seem that Messages app on Oreo did not support. Please help
profile.country.AT.title
skycamefalling
Contributor
Google's "Messages" app doesn't support templates, but you can use another SMS app from the play store.
1 REPLY 1
skycamefalling
Contributor
