How can I enable developer options?
Hi @BRIGGY, you can find the option to enable developer options on the link below that @alexdon posted and you can then access them in Settings > System.
If you later on want to remove the setting, you can clear data for the Settings application in Settings > Apps & notifications > App information > 3 dots > Show system > Settings > Storage > Clear data > OK.
I hope that helps!
Hello,
If you want to enable developer options.
That's how you enable the option of developer.
Thanks & Regards
Afflospark
