How to activate Wifi calling
Avery
Hello there,
I want to use the wifi calling function on my Sony Xperia xz phone but I don't know how to do that.
Can someone explain me how to find the function on the phone?
Or do I have to do an update, to activate the function.
Kind regards Avery
3 REPLIES 3
Jonas
Master
Hi @Avery, welcome to our forum!
If your network provider supports VoWifi (Voice over Wi-Fi) for Xperia XZ you can enable this feature in Settings > More > Wi-Fi Calling.
If you can't find the setting in this menu, get in contact with your service provider (operator) and ask them if they have enabled VoWifi for the Xperia XZ!
I hope that helps!
Alienskayaker
There is no 'More' in settings for the F8331
Jonas
Master
Hi @Alienskayaker, welcome to our forum!
That post was made when the device was still in Android 7 and in Android 8 (Oreo) the option to turn on Wi-Fi calling is in the phone application and you can enable it if you follow the instructions below.
Single SIM users
  1. Find and tap Phone
  2. Tap the menu button (three vertical dots) > Settings > Calls > Wi-Fi Calling. If Wi-Fi Calling isn't available, contact your network operator
  3. Tap the switch beside Off to enable Wi-Fi Calling
Dual SIM users
  2. Tap the menu button (three vertical dots) > Settings > Calling accounts > Select a SIM card > Wi-Fi Calling. If Wi-Fi Calling isn't available, contact your network operator
I hope that helps! Slightly_smiling_Face
