how to deactivate dictionary
LiveAeons
Hello!
How can I deactivate predictive text/dictionary on my XZ premium?
2 REPLIES 2
stanlykubrick
Contributor
Depending on the keyboard you are using...there is always a setting for this feature.
I am using Gboard myself but the setting applies to all keyboards.
Open Gboard app from the applications page...it should automatically go to settings.
Then go to Text correction > under Suggestions you can toggle off "Next-word suggestions" or make any other changes you feel are needed.
Please remember to KUDO if I was able to help!
manuel88
if you are using swift keyboard, go to settings - system - language & input - on screen keyboard - Swiftkeyboard - typing - typing & autocorrect,  there disable autocorrect and quick  prediction  insert.
