I've not used my XZ3 for a year. it has no SIM card and i've forgotten password. how to unlock?
Felixhope
5 REPLIES 5
AlexandruMunten
Felixhope
Companion won't work. It says unlock is required. don't know code or plan
AlexandruMunten
Make sure you know the username and password of your Google account.
- Computer: Download and install the Xperia Companion application from: https://support.sonymobile.com/es/xperia-companion/
- Open the Xperia Companion application.
- Turn off the terminal.
- Click on the box that has this phrase ¨I Can not detected or started¨ or “the computer does not detect the mobile”
- Connect the device to the computer with an original USB cable.
- Follow the instructions on the screen.
Note: remove the SD card and memory card before doing it
Felixhope
I'm afraid this does not work.
I've downloaded. Experia companion.
when you say "turnoff terminal" i'm assuming you mean 'phone' right? i've done this.
i open companion and it immediately jumps to unlock required. see attachScreenshot 2020-02-08 at 12.33.50.pngment
Felixhope
