Icon
Jpouille
Icon
Quelqu'un sais à quoi correspond l'icône + entouré dans la barre d'état en haut à droite ???
Merci
Someone know what is the + icon surrounded in the status bar at the top right ???
Thank you
GT
1 REPLY 1
profile.country.RO.title
_alexdon_
@Jpouille I have translated your question with google translate because this is an English only forum.
That icon refers to the data saver option which you should be able to find under quick settings or under data usage.
alexdon
