As You can see my navigation bar is messing with my keyboard when I play games. First it doesnt disappere, then it makes the keys flow into the next one. And lastly it goes completly White. Ive tried to use some hide navigationbar apps. But didnt work. Anyone els experianced issues like this?
http://imgur.com/gallery/nzNZFRQ
Its a #xz2
Flowing text and White navi bar
Hi @TwixieTrap, let me see if I can help out here!
Looking at the photo you attached in your post, it looks like you are using Xperia keyboard. Does the same behaviour persist in the pre-built keyboard app (Swiftkey)? Also, have you tried clearing data for the keyboard app? This will reset all settings for the app in question which might do the trick. Find and tap Settings > Apps & notifications > Show all XX apps > Swiftkey/Xperia Keyboard > Storage > Clear data.
Try this and let me know how it goes!
I made a complete reboot lf the Phone because it started acting strange. So the keyboard app data is wiped. And using the original keyboard. Havent tried SwiftKey
Thank you @TwixieTrap for your quick reply!
In this case, My suggestion is to use Swifkey, which is the original pre built keyboard. This due to the fact that Xperia Keyboard has not been updated in a while and therefor may have difficulties to work as intended.
I hope that helped!
