After this update, I have this issue where the phone shows as if no sim card is inserted immediately after the boot. It takes around 5 minutes for the phone to detect the sim cards. I had done a factory reset which seemed to have solved the issue, but the issue returned after installing the Google dialer, earlier before factory reset I had XZ3 dialer.
Anybody else facing this issue! Just after reboot the phone takes too long to detect the sim cards and networks, if you have a third party dialer/xz3 dialer installed.
I have dual sim variant. Phone detects the sim and network immediately if only one sim is inserted in either of the slots. Which means it is not a hardware issue. I believe it exists only in dual sim variant and is a software issue for phones with a non stock dialer.
Please can someone check and confirm if this issue exists?
I am also facing the same issue
