Light scratches Side frame polycarbonate
Alan1990
Hey
Ich got my Phone 3 months ago and used a transparent case from day 1. Now after cleaning the Phone 2-3 Times a month, i notced tiny, light scratches all around the Side frame. Both sides actually.
Now has anyone noticed the same issues till now? Its not so bad, but really...i dont this should happen to a Phone Like this.
Is there a way to fix this ?
Thank you for the replies
7 REPLIES 7
Antigatorre
Mi xperia Z5 premium le ocurrió lo mismo las esquinas ya no tienen el mismo color oro como si estuvieran gastadas
@Alan1990 wrote:
Hey
 My premium Xperia Z5 happened the same thing the corners no longer have the same gold color as if they were worn
GT
Species8472
Those tiny scrathes may caused by dust particles between case and phone. The Chromium plating is not very hard stuff, and under the plating are relatively soft polycarbonate. So it's not very scratch proof. I have too transparent case, and i wash it at least once a week because the dust, and wipe the phone microfiber cloth with tft display cleaning liquid.
MILSUM
Hi I HAVE THE SAME PROBLEM WITH MY SIDES OF THE XZ PREMIUM. DID YOU MANAGE TO FIND A SOLUTION TO THE PROBLEM. I WAS ADVISED TO USE COLGATE LIGHTLY AND THEREAFTER BLUFF IT OUT. WHATS YOUR ADVISE?
Tags (2)
profile.country.US.title
Qatrium
@MILSUM
My initial advice is to turn off your CAPS lock key.
MILSUM
hi what's the best to remove scratches from the sides of my Sony Xperia xz premium. it's made of polycarbonate plastic.
profile.country.PT.title
NunoSEN2
Hero
Hi @MILSUM;
I personally use a soft Display polish and it works but be careful because the polycarbonate is painted and if you polish to much or many times it will remove the paint.
Bigboss87
How do I get soft display finish
