Moving files
Kytty
Moving files
I've moved a large portion of photos from my Album to a file on my SD card.
Most of them seem to have transferred, however the 'task bar' in my notification shutter has been on '50%' and '9 hours remaining' for at least 5 hours.
I can't work out how to check if it has in fact finished transferring.
I am also wondering if I will lose any data if I restart my device?
I would attach a screenshot but you can't capture one of notifications.
Thank you in advance,
Kytty
Tags (2)
2 REPLIES 2
halogenic_sky
do you have/can you install any file system software, e.g. file commander? just run through the internal directories, and make sure all the photographs have been ported over to your sd card.....
Kytty
Thank you, I'll give that a try.
The progress bar actually went away after 3 days 😂
