Hi there,
I've been having an issue recently where the bottom navigation bar will just not go away at all when it really should. It'll still disappear for photos and videos etc, but in apps like Spotify (shown in photo) it'll still be there and it's really quite distracting. It's been happening since I updated a few days ago, is there any way I can change this? Why is this happening?
Any help is much appreciated!
I think they made a mistake with the new Android 9 update. Because it used to go away in certain apps. But with Android 9 you got to have to choose that option to always hide the navigation buttons. Which they would go away after certain amount of time. But so far it doesn't look like they added in the gestures or that option in the subsystem menu. Like it is with other phone such as the one plus six and the essential phone.
I am hoping that they see it and that they put it into the fix in the November security update.
Oh yes, this was the first thing that I have noticed after the update. I've noticed that on Sony native apps it goes away or it takes the background colour, but on others, like Spotify, not. And it's really bothering me because Spotify is all black and the navigation bar pops out on white, it's an eyesore.
After the new update, my menu line in buttom is always there now, and white now. How do I change that
I am facing same issue and its annoying. How do i get it off
Har samma problem efter uppdateringen. Navigeringsfältet försvinner inte .
Having the same problem after the update. The navigation bar will not disappear.
gt
Several Themes will change color and look on the navigation bar. :smileysmileywink:
That may be true. However I'm not using a theme and so my navigation bar should not be looked. Which it was not when the phone was on 8.0 and I know that in 9 you should have a choice to lock it or to have it hide when. You want it too
