Network or sim card error
Turbo123
Hallo ich benötige hilfe. Bei manchen anrufen Wechsel ich zwischen unbekannt und Rufnummer anzeigen. Seit zwei Tagen kann ich aber diese Einstellung nicht mehr ändern. PFAD: Einstellungen Anrufe zusätzliche Einstellungen. Sobald ich in diese Einstellung gehen möchte kommt der Fehler "Netzwerk oder sim Karten Fehler" ich habe schon Neustart probiert und mehrmals sim Karte raus und wieder rein aber der Fehler kommt immer noch
Hello I need help. With some call change I between unknown and call number show. For two days I can not change this attitude anymore. PATH: Settings calls additional settings. As soon as I want to go into this setting, the error "Network or sim card error" comes in. I have already tried rebooting and several times sim card out and back in but the error still comes
gt
1 REPLY 1
Jonas
Master
Hi @Turbo123, sorry to hear about this. Slightly_frowning_Face
Your question has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
If you are still experiencing this behaviour, do you have the possibility to try with a different SIM card in your device? If you can borrow one from a friend, colleague or family member and see if you can activate the settings with their SIM cards, as the error message points at this being related to the network.
Let me know if that helps!
