phone restart problem
santhosh20
I have facing issue from my new phone xz from last two weeks while I am using some applications, it's hanging and after restart.. please solve it
14 REPLIES 14
Uliwooly
@santhosh20
which applications?
Sunking1011
Contributor
Chrome freezes for me regularly, and FB does when I try to englarge a photo.
CameronT
Champion
Hi @Sunking101 and @santhosh20,
Can you please try it safemode and see if the same thing occurs with the default apps, such as Chrome?
barah
I'm facing the same problem i try repair the phone by pc or make factory reset without luck this problem appear after last nogut update,,
barah
I have solved the problem by downgrade to 6.0.1 now no restart so i think it's software problem please fix it sony.
RickyNg
Hello there,
Once I updated my xperia xz, it keep restart , restart and restart. It is so annoying until I almost throw it on the wall. Please fix it. The problem occured everytime I enlarge a phyo on facebook and watching youtube.
Already done factory reset and plugged in computer repaired. The problem still remain the same. It is without pluging in Sim card and memory card.
Thanks
RickyNg
Hello nolram, I did reset and repaired. It still happened again.... After I updated to nougat, restart loop nvr stop…
RickyNg
Happening now*
