Problem with fingerprint sensor
Dra1990
He tenido un problema con el sensor de huella dactilar.
Mi xperia xz3 es resistente al agua. ( cabe destacar que esta muy cuidado, nigun golpe, ni caída, ni nada roto).
Este se deslizó dentro de la bañera por unos segundos y lo saque de inmediato.
Apareció un mensaje de error de hardware  del sensor. Al reiniciarlo (una vez seco el smartphone) ha desaparecido la huella.
Es decir, como si el smartphone no tuviera huella dactilar. No aparece ni en el gestor de huellas dentro de "ajustes/opciones de bloqueo".
He probado a hacer un hard reset, pero sigue sin aparecer... #xperiaxz3
I had a problem with the fingerprint sensor.
My xperia xz3 is water resistant. (It should be noted that this is very careful, no blow, no fall, or anything broken).
This slipped into the tub for a few seconds and I pulled it out immediately.
A hardware sensor error message appeared. When you restart it (once the smartphone is dry) the trace has disappeared.
That is, as if the smartphone did not have a fingerprint. It does not appear in the fingerprint manager in "settings / blocking options".
I tried to do a hard reset, but it still does not appear ... # xperiaxz3
gt
2 REPLIES 2
Martin1
Enthusiast
Hi @Dra1990, sorry to hear about this.
As there is no setting available in the phone enabling you to add or remove the fingerprint manager from the settings, I suggest that you try to repair the software using a computer and Xperia Companion. Keep in mind though that a software repair will erase all user data from the phone, so make sure to do a backup of your user data before the repair.
If the fingerprint manager still does not appear after the software repair, I am afraid that the only thing left to do is to get in contact with your local support team in order to have your phone sent to an authorized service center to be examined and possibly repaired. If you have any questions regarding the service such as routines, warranty and consumer laws, these kind of questions are best answered by your local support team as well.
I hope that helped!
Vritra
It is water resistent only with the contact of clear sweetwater! Soaps, foam baths, shower gels or any surfactants change the surface tension so it probablay happened that water came into your device and made a short circuit. Perservering_Face
