Related to application saving location
kilee
I have trasnfered several apps to SD card from internal memory.
But if I update the apps in the Google Play, they return back to internal memory.
For example,
1. I have moved Instagram app to SD card.
2. Google play notify me there is an update.
3. I made the update.
4. Instagram app is located in internal memory, not in SD card.
5. I have to transfer the Instagram app to SD card again.
Is this a normal operation??
Lord_viridis
Yes.
Google play will always update apps internally in order to verify any paid licences in the drm partion
3 REPLIES 3
Lord_viridis
Yes.
profile.country.RO.title
_alexdon_
That is how it works, it has been asked before. There is a good explanation from Rickard here:
http://talk.sonymobile.com/t5/Software-Updates/Apps-moved-to-SD-card-still-reserve-space-in-internal...
alexdon
kilee
Thanks, Viridis and alexdon.
I didn’t know that@@
