Ringtone and notification volume
bobdole
Recently my ringtone and notification volume seems to get stuck on the minimum volume despite being able to move the volume slider around. It seems to happen after the device makes a bluetooth connection and then disconnects. Is anybody else experiencing their ringtone and notification volume randomly stuck at minimum despite being able to move the slider?
The volume works fine for a few hours after a reboot and media volume gets properly loud, I don't think it's a problem with the speakers.
3 REPLIES 3
Uliwooly
@bobdole
This could be a third party app acting up, you could boot in >>> safe mode for several hours and see if you experience the same issue, if you don't then it is a third party app.
Aslaugjo1
Yes, I have! I also connect to bluetooth in my car, that could be the problem! I just missed a call from my doctor!!! Now I have just upgraded the phone to the newest Android version (from Sony). Hope they have fixed this, fingers crossed!
Hamon
I have the same problem,. Should it be reported and returned to the Sony ?
