Whenever go into settings it goes to sd storage option I hit back and it shows. The settings menu for a short second the goes back into the sd storage menu. How do i fix this as I need to change settings. It always does this in portrait but works sometimes in landscape until you go into sd storage again
Well there's a turn up. Went to safe mode and was. OK then rebooted all OK.. When went funny was before I installed any so was basically a clean phone bar Google updates.
