Sharing connection
Fabrice01
Sharing connection
Salut à tous  j'ai besoin de partager ma connexion internet mobile avec mon ordinateur, je ne peux pas activer le point d'accès dans les paramètres. J'ai désactivé la sauvegarde automatique comme demandé mais ça fonctionne toujours pas  pourtant je l'ai déjà fait il y a quelques temps merci pour vos solutions
Hi all I need to share my mobile internet connection with my computer, I can not activate the access point in the settings. I have disabled the automatic backup as requested but it still does not work yet I already did it some time ago thanks for your solutions - GT
1 REPLY 1
Martin1
Enthusiast
Hi @Fabrice01 and welcome to our community! Slightly_smiling_Face
There are three possible ways to share your mobile data connection to another device such as your computer. Using a USB-cable, using bluetooth or using a portable Wi-Fi Hotspot. The different ways is displayed below.
Using a USB-cable
  1. Connect your device to a computer using a USB cable.
  2. Find and tap Settings > Network & Internet > Hotspot & tethering.
  3. Tap the switch beside USB tethering to turn the feature on, then tap OK.
  4. To stop sharing your data connection via a USB cable, find and tap Settings > Network & Internet > Hotspot & tethering, then tap the switch beside USB tethering to turn the feature off. You can also disconnect the USB cable
Using a portable Wi-Fi Hotspot
  1. Find and tap Settings > Network & Internet > Hotspot & tethering.
  2. If not already configured, tap Portable hotspot > Configure hotspot.
  3. Enter the Network name (SSID) and tap the Security field to select a security type. If required, enter a password.
  4. Tap SAVE.
  5. Tap the switch beside Off to turn the feature on, then tap OK. When activated, the tethering or hotspot active icon is visible in the status bar. Up to ten computers or other devices can now connect to this network.
  6. To stop sharing your data connection via Wi-Fi, find and tap Settings > Network & Internet > Hotspot & tethering > Portable hotspot, then tap the switch beside Onto turn the feature off.
Using Bluetooth
  1. Make sure Bluetooth is activated on both your computer and your device.
  2. Pair your phone with your computer.
  3. Configure your computer to obtain its network connection via Bluetooth. For more information on how to do this, see your computer’s user guide.
  4. Find and tap Settings > Network & Internet > Hotspot & tethering.
  5. Tap the switch beside Bluetooth tethering to turn the feature on.
  6. To stop sharing your data connection via the Bluetooth, find and tap Settings > Network & Internet > Hotspot & tethering, then tap the switch beside Bluetooth tethering to turn the feature off.
I hope that this information was somewhat helpful. If there is anything else i can help you with, feel free to ask! Slightly_smiling_Face
