Smart call handling missing after october update
Jeffrey04
https://support.sonymobile.com/global-en/xperiaxz1/userguide/smart-call-handling/
The call menu seems to be missing after the update (checked again in safe mode, it isn't there too)
Lord_viridis
Are you using dual SIM?
Check the information here for finding the setting in dual SIM version
https://support.sonymobile.com/global-en/xperiaxz1dualsim/userguide/smart-call-handling/
4 REPLIES 4
tomo100brt
It is not missing. I found it in
Phone --> three dots --> Settings --> Calls
if you are looking for this.
Lord_viridis
hemantjshah61
Hi friends, I to have notice that call option is missing in phone setting app after I got Oreo update
Jeffrey04
yea, they relocate everything in oreo, follow the instructions above to find it
