Sony Xperia Weather App Showing Incorrect Time On Sony Xperia XZ
066027
In the United Kingdom the clocks went back 1 hour this morning. The network provided time on the phone is correct however the Sony Xperia Weather Weather application is still showing the clock an hour ahead.
066027
Now the app is showing the correct time, lets hope it lasts
4 REPLIES 4
profile.country.RO.title
_alexdon_
Strange, can you remove the widget and restart the device? Then add the widget again.
Works fine here on X and Z5c.
alexdon
066027
Just checked the phone again and the app has now corrected itself to the correct time
066027
Futher update the time is now incorrect by an hour again.
Removed the widget, reboooted the phone, reapplied the widget - correct time shown.
Setup app to show weather for my location - incorrect time shown (One hour ahead)
066027
