Sony Xperia XZ2 Android 10 Sound distortion problem
Scott2002
My Sony XZ2 after a Android 10 update [52.1.A.0.532] The sound of it from both speaker and headhphone become distortion but before Android 10 update it was normal.
Does anyone else have the same problem ? and how to fix them ?
[I already factory reset it and it didn't work]
2 REPLIES 2
Guado43
I have the same problem and I don't know how to fix it. Do you maybe know it by now? It's like the cracking sound every few seconds.
Scott2002
No,I have not found a way to fix it yet.
I think the best solution right now is to wait for the new update or try downgrade to Android 9.
I hope Sony will fix this problem in the next update.
