Spotify and EQs
ElMarco
Spotify and EQs
Hi everyone,
everytime i use ClearAudio+ or i set the eq in the phone settings Spotify doesn't work properly. The volume goes down and  then up when a song starts and also if you skip parts in a song. Can Sony Fix this?
2 REPLIES 2
profile.country.PL.title
najodleglejszy
@ElMarco does the same thing happen when using some other music players? because if it's only exclusive to Spotify, then it's a Spotify bug and you should contact their support and let them know about your issue, so that they can investigate it.
ElMarco
I haven't tried other streaming services but in the music app doesn't have any problem. I already contacted the spotify support and they said that that's not an app bug.
