I would like to know if we can adjust the sensitivity of the touch by what I find that its going too fast compared to my xz
I bought the xz1
J'aimerais savoir si on peut régler la sensibilité du tactile par ce que je trouve que sa va trop vite par rapport à mon xz
J'ai acheté le xz1
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
There isn't a way to do so
