Volume output/ dac
Dallon426
Volume output/ dac
Is there any fix for this other than buying a usb-c dongle?
Don't is supposed to be known for excellent sound quality.  But this is pretty bad. Volume is far too low, bass is weak.  It just sounds weak.  I would like to be able to drive my bose headphones but can't get enough push.  Is there anyway to completely disable Sony sound settings so I can use an app to achieve better results?
Or some update to give us higher quality and lowerl output?
2 REPLIES 2
Dallon426
I'd love to get more bass.  I've adjusted all settings and have tried various apps to no avail 😕
halogenic_sky
try "neutron" from the play store - the user interface isn't the best but the sound options are incredible, and there's enough to get your teeth into 😉
