White dots on screen
kenny-tetsuya
I can occasionally see some white dots on the screen. Tried to take a photo of it but they are not easily visible. So the camera cannot cpature it.
I noticed this issue by chance and I assume that it is not a software issue as I changed the wallpaper and the dots are still there.
The white dots are not always there. Sometimes they pop up when the screen brightness is very high.
Anyone else having this issue?
11 REPLIES 11
Emil
Enthusiast
Hi @kenny-tetsuya,
I'm sorry to hear this. Slightly_frowning_Face
I recommend that you test your display in the the diagnostics tool in your device. You can do so if you go to: Settings > About phone > Diagnostics > Test > Display.
Do the white dots show up in this test every time you try to test?
Let me know how it goes! Slightly_smiling_Face
kenny-tetsuya
@Emil wrote:
Hi @kenny-tetsuya,
I tried the diagnostics. Seems like the dots are not visible as it provides only black and white colours for testing. But I can still see the white dots when I jump out the diagnostics. They tend to be more visible in non-black and white colours.
How reliable is the diagnostics though? If the diagnostics is right, then it should be a software isssue?
Emil
Enthusiast
Thanks for getting back to me.
If the dots where due to pixel errors they should have been visible when the screen turns black in the diagnostics test.
I recommend that you reboot your device to safe mode to see if this behavior is caused by one of your downloaded apps as these will be temporarily disabled in this mode.
If you are still experiencing the same behavior I recommend that you perform a software repair using Xperia Companion.
Keep me posted how it goes.
kenny-tetsuya
I just tested in under the safe mode. The dots are still visible....It can be a physical fault of the screen?
But I bought this phone from a reliable eBay store as XZ1 is not released here in Australia, which means I cannot get a free repair from Sony Australia?
Emil
Enthusiast
Did you have a chance to try a software repair using Xperia Companion aswell?
For any warranty related questions you should get in contact with your Local support team. This is a international community and your local support team is better equipped to assist  you with questions regarding warranty.
Alexdc12
I have white dots on my screen, i say dots they are more spots, not a true pixel i wouldnt say.
If i do the screen test i notice them most on the white screen.
Not too happy about having to send this off though as i always go over a week without a phone!
Emil
Enthusiast
Hi @Alexdc12,
Have you tried the other troubleshooting suggested in this thread as well? safe mode and performing a software repair using Xperia Companion?
Alexdc12
No i havent tried SAFE mode as it displays in teh screen test screen.
I refuse to do a software reset as cant see its software related, i have already had to do software resets within weeks of owning the phone for another problem!
Its like buying a car and taking it back to the garage and they say rebuild the engine before you bring it back!
Chakotey3
Do you mean something like that?
If it's the same...then it's "normal" 😛
You can see the Matrix from the Display ^^ only on Sonydevices.
