wifi problem xz1 compact
Kevinod
Phone is useless. Cannot use at home for more than couple of minutes before wifi goes slow and keeps stopping. Have reset phone.deleted caches history etc. Switched off router. Nothing works.
10 REPLIES 10
Sevdar
Sony will release update
But dont know when
AREK28
I have the same problem, my WiFi frequently gets disconnected, same as my Bluetooth, I had to restart my phone to get them working again, i had emailed Sony Mobile support and had followed all their instructions to troubleshoot the phone but still no solution, i really regretted buying this phone, should have stuck with Samsung... Slightly_frowning_Face
Theevilmonkey
Anyone found a solution to this yet ?
chichudox
I got the same problem just a few days ago I updated to v. 47.1.A.12.179 and the wifi suddenly disconnected at anytime.
Then I can't connect again to the WiFi network due the whole mobile stuck.
Needs to restart to fix it.
I love my phone but this problem is driving me crazy.
pseudonym
Contributor
Have a similar wifi (not bluetooth) problem using firmware .145. Restart fixes, but eventually the problem resurfaces again. May wait to update until firmware following .179 is available.
Profyler1
Contributor
Yeah, this problem came back for me. Happens 1 or 2x per day... Very strange...
Wifi looses conection for a few seconds than reconect itself.
granis
The same problem for me, but after 10-20 minutes the wifi starts again without doing anything! And if I try to restart the mobil it takes very long time until it starts again. Up to 30 minutes. Irritating.
Lord_Bavington
This is so unbelievably frustrating. It can see the WiFi connections available, but refuses to connect to them. I have an XZ1 Compact. I just get a question mark next to the WiFi logo. It has been happening for months. The problem is fixed when I restart the phone, but its now happened for the THIRD time today. Not good enough Sony, especially when you've know about this problem for so long. I can't recommend Sony phones to anyone because of it. I should have stuck to Samsung.
Damo_
Contributor
Mods / admins: do you know if this (WiFi issue) has been raised to Sony? Not trying to get this post locked but I've never seen any comment around it (if it has been raised / that they are aware) and as I imported my device (as Sony in my country do not sell the device) I'm not able to get any information out of local support.
Just try to get some acknowledgement that Sony are aware of it...
